Rohan Wiese
SQL Database Repair Tool is the best SQL Server Database Recovery utility in the entire world that helps to repair the corrupt SQL Server Database file. It repairs the MDF file of the SQL Server Database and restores the data from the MDF file successfully.
Follow the Solution Steps to Repair SQL Database
- Install and Run SQL Database Repair Tool
- Open the Software and Select the corrupted and damaged MDF file.
- Click on the Ok button then scan the selected MDF file.
- After scanning double click on recovered MDF file and preview their items.
- Click on the Save button the recovered MDF save into the new SQL Database file.
