I am trying to run this against my secondary IDE Drive. I want to run it on the whole drive. (This erase is on Windows 7 64-bit)
If I run the 6.0.6.1376 I get this message:
Error StartIndex cannot be less than zero.
Error Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED))
If I try to run it as administrator then I get the following break:
Description:
Stopped working
Problem signature:
Problem Event Name: APPCRASH
Application Name: Eraser.exe
Application Version: 6.0.6.1376
Application Timestamp: 4b26dc33
Fault Module Name: mscorwks.dll
Fault Module Version: 2.0.50727.4927
Fault Module Timestamp: 4a27466f
Exception Code: c0000005
Exception Offset: 00000000001c2313
OS Version: 6.1.7600.2.0.0.256.1
Locale ID: 1033
If I download and install and try to run 6.0.6.1518 I get this:
Description:
Stopped working
Problem signature:
Application Version: 6.0.6.1518
Application Timestamp: 4b4eb5c3
Exception Offset: 00000000001c22e1
Locale ID: 1033
Description:
Stopped working
Problem signature:
Locale ID: 1033
Description:
Stopped working
Problem signature:
Locale ID: 1033
