The Excel to vCard Converter Tool, which is free to try, is the preferred solution by professionals for converting XLS to VCF. Any Excel file with an infinite number of contacts can be easily converted. The app makes the conversion simple and provides you with 100 percent accurate results every time.
The following are the main features of Excel to vCard Converter:
1. Convert all things in an Excel file to vCard format with ease.
2. Display an Excel interaction preview
3. A program that is both interactive and simple to use.
4. Import contacts from any size Excel file into a VCF file with ease.
5. Allow Excel contacts to be mapped to VCF files.
6. A free trial version is available to test the app.
7. Ensure that all communication properties are preserved in the conversion.
8. It's a stand-alone application that doesn't need any additional software.
9. Converting an Excel file to a VCF file quickly and safely
