If you want to convert Excel to VCF, you can use its third-party Excel to Vcard Converter app, which only requires one or two clicks to get started.
Steps to export Excel contacts to CSV file
• Open Excel file.
• Click on the Office button in the Excel window
• Now, click on Save as and choose other formats
• Select the folder or location to save the file
• In Save
• type option, click on the drop-down menu
• Select CSV (Comma Separated Value) option
• Click on the save button and confirm Yes
• Your Excel file is now converted into a CSV file
Through the steps looks simple but you have to follow each and every step with utmost care to convert excel contacts to VCF without any errors.
• Open Excel file.
• In Save
