I suggest reading this blog post: XLS to VCF file conversion if you need to convert an Excel file to vCard format. The blog will walk you through the process of manually converting Excel contacts to vCard format. To begin, convert the Excel file to CSV format. After that, you can import contacts from a CSV file into your scheme. You can then export all of your contacts to VCF format.
Read More: Excel to Vcard Converter
