If you want to convert the Excel file to vCard format then, you can go for This Excel to vCard Converter. The software Export multiple contacts in batch. Also, Users can create a single .vcf file for each contact.
Valuable features of XLSX to VCF Converter
• You can easily export all contacts from an Excel file without having to worry about file size limitations
• You can map Excel contact fields to vCard fields
• You can easily create a single VCF file with all Excel contacts • Free to use for evaluation before investing
• 100 percent safe and quick transfer
Read More: SYSessential Excel to VCF Converter
