Quick question (for a change) before I get some much needed sleep.
Can anyone tell me what the following means or why on earth it is happening. On logging in (to Win XP SP2+hf) I get eraser.exe (6.0.4.875) popping up a cmd window that says the following:
This as you'd expect just sits there until you press a key after which point eraser loads to the system tray.
Code:
The given Key was not present in dictionary.
...Press any key to continue...
