My old computer (1996-Windows 95 era) doesn't have USB connections and is not on the internet. It does have a CD-ROM drive. Is there a way to copy Eraser from my newer computer onto a CD and then use it on the old computer to erase files? Which folder/files would I copy off my downloaded Eraser (v.5.7)?
Thanks Overwriter,
Now if only I knew how to find Eraser "Installer." I have downloaded Eraser 5.7, but I can't find any file labeled "Eraser Installer." Not sure what I'm doing wrong. I can find Eraser Setup, but not "Installer." Help!
I have the same problem. I downloaded Eraser to my zip drive, but there is no Install or Setup file - only Uninstall. I can't get it to work on the computer I want to Erase. What should I do? Thx.
