Vartika OLM to PST Converter
If you have the Mac Outlook OLM file but no longer have access to the computer that created the OLM file and you want to convert into PST, you'll need to use a tool to recover the data of the OST. Here, I would like to suggest you download Vartika OLM to PST Conversion tool. By using this tool, you can easily repair damaged Outlook OLM file mailbox data and recovers into PST file, NSF, vCal, EML, HTML, vCard, MSG, EMLx, MBOX file formats. It capable to supports all the versions of OS Windows 95, 98, Win 8, Win 10, Win 8.1, Win 7, Win Vista, Win XP, Win ME and Win NT. The software allows you to split any big amount of OST file to Multiple small PST file formats. 2010, 2007, 2003, 2002, 2019, 2016 and 2013 versions of MS-Outlook.
Read more : Vartika OLM to PST Converter- Convert OLM to Windows Outlook
"Best OLM to PST Converter Software which can easily trans fer all OLM files into Outlook PST, including emails, contacts and calendars of Outlook for Mac OLM files to MS Outlook PST files.This software easy to migrate all mail components from OLM, such as the Inbox, Contacts, Calendars, Notes, Tasks and etc.It also supported all updated versions of Windows Operating System.
If you want to convert OLM to PST file format, you can use OLM to PST Converter for Mac Tool. The application simple to switch all email items such as emails, attachments, contacts, calendars, and account information, etc. I would like to this software for Mac It allows the user to convert OLM files into Outlook PST Format. This software work very fast and quickly. All Mac OS versions are perfect for using this program. For getting more material about this program, you can free to download it using a free trial edition facility.
Converting OLM files to PST files is often necessary when moving from Outlook for Mac to Outlook for Windows. Here are some important features we need to consider before choosing any OLM to PST Converter Software such as their compatibility, reliability, work efficiency, technical support, etc. These are all the features we need to consider before choosing any OLM to PST Converter. So, based on the abovementioned features I recommend that the best application is known as Softaken OLM to PST Converter Software. With the help of this application, you can easily convert your bulk of OLM files to PST format in just a few simple and quick steps.
  1. Download and run the program.
  2. Select the OLM file to convert
  3. Get a preview of OLM files data’
  4. Choose PST file format to convert OLM file into PST’
  5. Select the desired location to save resulted data at your desired location
  6. Click on the convert button
This advanced software smoothly works with all Editions of Microsoft Windows. Additionally, you can also download the trial version of this program to learn more about its advanced features.
Download CubexSoft OLM to PST Converter Tool if you're looking for an easy and quick way to migrate OLM data to PST files. It can export multiple OLM file, including contacts, tasks, emails, journals, and more, into a PST file. With no file size limitations, the utility easily transforms your large-size Mac Outlook emails to PST format. This program can be used by both technical and beginners alike to export Outlook for Mac OLM data to the PST format. All versions of Windows, Mac OS, and Outlook are supported. For transferring the first 25 items/folder, use the free trial version.
