vames
The easiest way to convert MBOX to Maildir is by using a simple and reliable tool-based method.
First, you can try a manual approach using an email client like Mozilla Thunderbird or Linux mail systems. In this method, you import the MBOX file so all emails appear inside the client. Then you use export or migration options to save the emails into Maildir format. However, this process can be a bit complex, especially for beginners, and may require extra configuration.
To make things easier, many users prefer a professional solution. A tool like MBOX to PST Converter helps process MBOX files in bulk and makes the conversion process faster and more organized. It keeps emails, folders, and attachments properly structured, which reduces the chances of data loss or formatting issues.
So, while manual methods exist, using a dedicated tool is the simplest and most efficient way to convert MBOX to Maildir.
