What’s the simplest way to change PST emails into RTF?
vames
The simplest way to change PST emails into RTF is by using the built-in option in Microsoft Outlook. Just open your PST file, select the email you want, go to File → Save As, and choose Rich Text Format (.rtf). It’s quick, easy, and works well if you only have a few emails to convert.
However, if you’re dealing with multiple emails, this method can become repetitive. In that case, the BLR PST Converter Tool can make things much simpler by allowing you to convert many emails at once without going through the same steps repeatedly.
Using a reliable PST file converter also helps ensure that formatting, attachments, and email details are preserved during the conversion.
So, for a handful of emails, Outlook is enough—but for bulk tasks, using a proper tool saves a lot of time and effort.
