Ramveersingh
There are several scenarios where converting an OST file to PST becomes necessary. For example, an OST file might become inaccessible due to a sudden power outage, a server crash, or an orphaned file caused by changes in the Outlook profile. Additionally, users may want to open a different OST file in the same Outlook setup.
Unfortunately, there’s no built-in method to directly use an OST file in all versions of MS Outlook. To convert an OST file to PST, third-party software is required. I highly recommend downloading and installing GoldyTools Best OST to PST Converter for a smooth and efficient conversion process.
Key Features:
Key Features:
- Quick OST to PST Conversion: Easily convert OST files to PST format in just a few steps.
- Additional Conversion Options: Convert OST to EML and MSG formats, offering flexibility for various needs.
- Wide Compatibility: Supports all versions of Microsoft Outlook (both 32-bit and 64-bit editions).
- Full Windows OS Support: Fully compatible with all versions of Windows OS.
