Will Eraser Secure Move work over home network?
phkhgh
Using Eraser 5.86.1 on two machines. Will Secure Move work (generally) over a home network?
Want to move files from PC w/ XP SP-3 to a new PC w/ Vista x64 hm prem. Just not sure if Eraser is designed to erase or secure move files across ANY network, even if the files are set to "Share."
Thanks.
It should, but there will no longer be any guarantee whether the secure move is really going to be secure because there's another abstraction layer of the network which may affect the order of which the file is overwritten on the host computer. I'd suggest you do the moving from the host to begin with.
