Just a few questions
xlnc78
hi just got a few questions and would appreciate it if u can help, im kinda new using this software
1. How do i know that the erase has fully worked?, what should i be looking for in the log?
i have read your tutorial and what im getting differs a bit with what u have shown on the print screen.
On the main screen, after i have chosen what method i like, im getting something like this:
----> [ ] (IDE 0,0,0,-,-) WDC AC21000H
[ ] (IDE 0,0,0,-,1) Partition
2. which option to i select for me to have FULL erase? ( every thing must go including partitions etc)
3. If i opt for 2 rounds, choosing the Gutmann method, does that mean the Gutmann method will run twice with 35 passes each round? if so what is the max number of rounds possible?
4. After i have erased the hard drive using a method from dban and ready to install windows, if it asks me to format the hard drive, should i do it?, is there any point since all the data is gone for good anyway?
thanks for ur help!!
kind regards!
DBAN will say "successful" on the screen.
The first. Partitions within this disk will be marked "[****]".
Yes.
Yes, or the operating system will not be installed.
