W 7 64 bit wont run eraser after install
This may provide a clue, from debug.log:
Application Information
Version: 6.0.6.1733
Command Line: C:\Program Files\Eraser\Eraser.exe
Exception Information (Outermost to innermost)
Exception 1:
Message: Window handle already exists.
Exception Type: System.InvalidOperationException
Stack Trace [0]: at System.Windows.Forms.NativeWindow.CheckReleased()
Stack Trace [1]: at System.Windows.Forms.NativeWindow.CreateHandle(CreateParams cp)
Stack Trace [2]: at System.Windows.Forms.Control.CreateHandle()
Stack Trace [3]: at System.Windows.Forms.Form.CreateHandle()
Stack Trace [4]: at Eraser.MainForm..ctor()
Stack Trace [5]: at Eraser.Program.OnGUIInitInstance(Object sender)
Stack Trace [6]: at Eraser.GUIProgram.Run()
Stack Trace [7]: at Eraser.Program.GUIMain(String[] commandLine)
Stack Trace [8]: at Eraser.Program.Main(String[] commandLine)
I get 2 crash logs for some reason, the Debug.log from the 2nd one looks like this:
Version: 6.0.6.1733
Exception 1:
Message: Object reference not set to an instance of an object.
Exception Type: System.NullReferenceException
Stack Trace [0]: at Eraser.GUIProgram.Run()
Stack Trace [1]: at Eraser.Program.GUIMain(String[] commandLine)
Stack Trace [2]: at Eraser.Program.Main(String[] commandLine)
Thanks for the crash logs. That helps. I've got a fix in r1734 that should address this. Use any build later than this and let me know if it's fixed.
It should be available in about an hour and a half.
